btn
btn
1 of 2
lilchrissyy lilchrissyy
9/5/2013 1:23 PM
well guys snapped my brakecable (was running a straight cable) and i am thinking of converting too a giro system i have read the thread futher down about the best set up for brakes and i am having trouble sourcing some of the parts and this is the best set up i can come across am wanting a duel cable system all the way to the brake calipers
odyssey m2 lever
http://www.sourcebmx.com/product/components/bmx-brake-levers/odyssey-m2-lever/7741.shtml
odyssey m2 cable
http://www.sourcebmx.com/product/components/bmx-brake-cables-gyros/odyssey-m2-cable/13203.shtml
snafu mobeus gyro
http://www.sourcebmx.com/product/components/bmx-brake-cables-amp-gyros/snafu-mobeus-gyro/7551.shtml
vocal pro linear duel lower cable
http://www.sourcebmx.com/product/components/bmx-brake-cables-amp-gyros/vocal-pro-linear-dual-lower-gyro-cable/18812.shtml
i think i have the thingy the duel lower cable runs on too the london mod?
http://www.google.co.uk/imgres?imgurl=http://img697.imageshack.us/img697/5821/londonmod.jpg&imgrefurl=http://www.bmx-forum.com/t/83129/help-london-mod&h=548&w=640&sz=92&tbnid=x1gJzY0eX_IdeM:&tbnh=90&tbnw=105&zoom=1&usg=__zv_lDlfT8wgO2bNqEAZlBamezOU=&docid=mqJvUcEjmAet1M&sa=X&ei=sucoUpz1HOqw0wXvw4HYBQ&ved=0CC8Q9QEwAA&dur=322
what do you guys think? if anyone has any other suggestions or i have missed anything then feel free to comment just want to order the best i can for not stupid money and if anyone wants to change anything then feel free to comment smile
edit: ive still got my evos that i can use as calipers still there fine could use some more brake pads though smile
| Quote
ajohn15 ajohn15
9/5/2013 1:37 PM
Looks good!
The m2 lever comes with the cable.
| Quote
9/5/2013 2:15 PM
What you guys think about the lower cable? Not heard much about it really?
| Quote
fitbikerider14 fitbikerider14
9/5/2013 3:07 PM
That looks good but I would get 2 odyssey cables for the lower. Cant forget the small things: plate tabs
My Fit
| Quote
9/5/2013 3:15 PM
Ohh yer thanks man haha forgot the tabs!! Ready for the noob question of the day
Cause I want to run a duel system for the lower cable can I just buy 2 single cables and attach to the gyro plate at the top and then London mod at the bottom and a link to the cables that you would suggest if possible?
| Quote
9/5/2013 3:25 PM
You would run the cables through the bottom tabs and into the gyro. The top plate is for the top cable. The london mod goes on your cable stop at the back and lets you adjust each side of the brakes via barrel adjusters. And you would also need some barrel adjusters for the bottom cables since a regular cable doesn't come with one.
My Fit
| Quote
HardBMX_Tim HardBMX_Tim
9/5/2013 9:18 PM
-Odyssey m2 lever (comes with cables)
-Any detangler plate will do (flip it upside down if it doesn't)
-Odyssey GTX detangler, which I prefer because its sealed bearing instead of that retarded Snafu teflon bearing.
-Tree SB cables x2
-Any london mod.. Odyssey, Snafu, and Stolen make them.. probably more companies too
-Any high quality U-Brake should do. Everyone says "Odyssey, Odyssey, Odyssey!!" But they're pretty much all the same. Just pick one you like lol.
-Odyssey or Koolstop pads if you want clear, Fly if you don't (purple fly pads + chrome rims is the best set up I've ever had)
| Quote
9/5/2013 9:21 PM
lilchrissyy wrote:
Ohh yer thanks man haha ...more
They have to have a little ball on the end of the cable that sits flush in the detangler. I know Odyssey Slics have them, Tree SBs have them, and Kink has em too. I'm sure there's other companies that do but I couldn't name them lol. But if you're on budget, get Snafu Lower dual cables. It comes with both dual cables and a london mod
| Quote
9/6/2013 7:52 AM
looking at this cable
http://www.sourcebmx.com/product/components/bmx-brake-cables-amp-gyros/odyssey-linear-sls-cable/11813.shtml
am right in saying that the little ball bit at one end of the cable will go on the detangler and then what i could do is clip the other end off the cable to thread a london mod through and then attach a cable karp i think its called? onto the end of the cable when cut to my desired length and then attach that to the arm of the caliper?
| Quote
BMX_Forever BMX_Forever
9/6/2013 8:19 AM
...more
That might work however it's not what it's designed for. It's much cheaper to just buy normal Dual Cables.
| Quote
9/6/2013 8:27 AM
in the uk mate the only dual cables i can find for gyro system are the vocals link quoted in first post as its for the bike in my avatar pic and am wanting a full black brake set up
| Quote
element4all element4all
9/6/2013 10:10 AM
ive always run snafu upper and dual lowers with the astroglide detangler. all works perfect and is smooth as can be. but i do definitely recommend the dual lower cables. it will give you a better feel to brakes and be able to adjust each arm more.
"Forget 'today', 'today' is just tomorrow, disguised as yesterday"
TRANSPORTATION CHECK
Refs: ThrowAfit, 2funny4u, ridebmx456, spikez5, irideafly and a bunch of others, I'M LEGIT.
email= element4all@yahoo.com
facebook.
Instagram
| Quote
9/6/2013 10:17 AM
but what ive beensaying is am having trouble sourcing a dual lower cable as am uk and winstanleys and source have only got the vocal pro lower dual cable that it
| Quote
9/6/2013 7:01 PM
The odyssey cables will work you just need to make sure you buy barrel adjusters and the london mod separately.
My Fit
| Quote
9/6/2013 7:02 PM
What brakes are you running you might need a knarp on the end of the cable if you run open ended brake arms (ex: odyssey)
My Fit
| Quote
9/7/2013 12:24 AM
Am running original evos
| Quote
9/7/2013 10:07 AM
Is anyone able to source me a dual lower brake cable for gyro that can be attached to detangler and a London mod and also some removeble gyro tabs for wtp volta 2011 frame am uk remember
| Quote
9/7/2013 11:35 AM
Ok so I found everything you need at alans bmx
gyro
Lower cables with lonond mod
M2 lever with cable
Top plate
Bottom tabs
these might come in handy too
Is your frame drilled for the gyro tabs on the head tube? What size bars do you have?
My Fit
| Quote
9/7/2013 11:40 AM
Bars are 9" inch shadow vultus am 6ft 3 haha
| Quote
9/7/2013 11:42 AM
I've been looking T the snafu dual lower cables with London mod but try say out of stock on the website an other websites have said discontinued sad that's what am having trouble with
| Quote
9/7/2013 11:44 AM
You might not wanna go with the m2 lever because when I had the housing barley fit and my bars are 8.5. I'm getting 9 inch bars as well and I'm gonna get this
My Fit
| Quote
9/7/2013 11:45 AM
You would have to modify your monolever or get a different lever to run this tho
My Fit
| Quote
9/7/2013 11:46 AM
lilchrissyy wrote:
I've been looking T the ...more
Damn dude that sucks well if you have those knarps that go in the brake arms you can just take them off and buy 2 regular cable to use with your london mod.
My Fit
| Quote
9/7/2013 11:55 AM
Ok so they have everything here but you would have to buy the gyro parts at alans or somewhere else
Lever
Cable x2
Top plate
Bottom tabs
Upper cable
knarps
and you said you have a london mod already right?
My Fit
| Quote
9/7/2013 12:42 PM
Ok mate I've priced up some stuff here
An also I've put these cables on the price list the 1.5 have gyro ball end on one side and there's a lug on one end but am right in saying cut the lug end off put through a London mod and a Karp on
http://www.winstanleysbmx.com/product/1009/Odyssey_Slic_Kable_Straight
| Quote
9/7/2013 12:43 PM
A am right in saying they will be long enough to cut and put a Karl on and they will be ok cutting the end? Just worried about length now haha
| Quote
9/7/2013 12:48 PM
They might work because I know with my bike the cable housing was like perfect but I cut the cable and put knarps on it so Idk it might work. Don't forget the top and bottom tabs
My Fit
| Quote
9/7/2013 12:53 PM
Yer no worries man they should be long enough it will just have to be a case of measure twice cut once just gotta add the gyro tabs that go onto the head tube and barrel adjusters for the cable dam am gonna have a field day setting this up.....
| Quote
9/7/2013 1:00 PM
Lol it should take like half an hour but its satisfying when you dial it in and its smooth as shit. Hey let me know or post somthing when you get the stuff I wanna know if the m2 works because I would use it but I want to get 9 inch bars.
My Fit
| Quote
9/7/2013 1:13 PM
Instead of pissing about with cables an stuff might get these
http://www.winstanleysbmx.com/product/46405/Vocal_Pro_Linear_Dual_Lower_Gyro_Cable
But never had experience with vocal don't know how good the parts are ... An yer I will do mate !!! If the m2 lever don't fit il send it back
| Quote
btn
btn
1 of 2
Post a Reply
See All Deals ยป
THE SHOP
