Coopers25 Coopers25
2/17/2014 9:10 PM
i always see frames 3/16 dropouts and others with 4mm, 5mm, ect ect. I always presume 3/16 was thin but im not 100% sure. I went ahead and divided the 3/16 and got 0.1875 hen converted that into mm and got 4.7625. If the math is correct does that mean 3/16 dropouts are thicker than frames with 4mm dropouts? The thought just occured to me earlier to me and I don't think i did the math right. I just want to be 100% sure so don't prejudice frames or forks labeled with 3/16 dropouts for when I choose a frame or fork or whatever
| Quote
oscar5788 oscar5788
2/17/2014 9:19 PM
quick google search showed
3/16" = (3/16) * 25.4 = 4.7625 mm
BikeCheck Refs:
BEASTASSDICKwink,Flocka Myers, ecuadevil,White Knight, bmxing12 ,obiwan chromoly,ScramHype, Hatebreeder,SnM An1mal,isnowyaznV2
| Quote
Xxohioanxx Xxohioanxx
2/17/2014 9:23 PM
Yep, 3/16"=4.7625mm, which is plenty strong for both front and back when used with any axle as strong or stronger than 14mm male. Most people don't realize that dropout strength is largely dependent on axle strength.
YOU AVIN A LAUGH M8?
┬┴┬┴┤ ( ͡° ͜ʖ├┬┴┬┴
The Trailest Bike On Vital
| Quote
Coopers25 Coopers25
2/17/2014 9:27 PM
oscar5788 wrote:
quick google search showed ...more
So its pretty much just the same if not a little thicker? just double checking here
| Quote
Coopers25 Coopers25
2/17/2014 10:13 PM
Xxohioanxx wrote:
Yep, 3/16"=4.7625mm, which ...more
so female axle hubs in the back are a no go then? so for maximum strength I would go with a male axle over the female axle?
| Quote
Collin_McClenahan Collin_McClenahan
2/17/2014 10:15 PM
Coopers25 wrote:
so female axle hubs in the ...more
3/8 female is as strong or stronger than 14mm male.
FBM Pizza Beer Roast Machine
| Quote
Coopers25 Coopers25
2/17/2014 10:22 PM
Another question what if the center axles are bigger than 14 mm like the shadow btr (17mm) and the gsport ratchet (20mm) ? would male axles still be better than those two??
| Quote
Gump Gump
2/17/2014 10:30 PM
A 17mm-20mm female center with 14mm bolts will be stronger than any male axles
| Quote
isnowyaznV2 isnowyaznV2
2/17/2014 10:34 PM
Anyhow.. My Director forks are unique so they have hollow dropouts that are 10mm thick along with the whole fork blade/leg infused as the dropout.
| Quote
eskimojay eskimojay
2/18/2014 12:05 AM
Never once cared or worried about dropout thickness or had any problems with dropouts .......after 13 years of riding and not having an issue I don't see myself caring about dropout thickness in the future I would think that's overthinking something I don't need to worry about
| Quote
2/18/2014 2:59 PM
Not at all! Even "shemale" axles with 3/8" bolts into a 14mm axle are stronger than 14mm male axles. And that's the weakest form of female axles. Legit female axles are much, much stronger than 14mm male axles.
┬┴┬┴┤ ( ͡° ͜ʖ├┬┴┬┴
| Quote
Post a Reply
See All Deals »
THE SHOP
