The easiest way to do it is by using a rotary tool such as a Dremel. Use a wider cutting bit for about 3/4 of the axle, then use a thin cutting bit to finish the rest. Then use your grinding bit and grind the end smooth. During this whole procedure, try not to fuck up the axle threads.
REFS: trickbiker169, Dah Man, letstartariot, Hofmann Scarab
3PieceWillie wrote:The easiest way to do it ...more
i used a hacksaw on my front wheel, left the back alone
i am looking to cut my axles down to the bolt and was was wondering what to use and how to do it. thanks.
Post edited by: dirtjumper92, at: 9/6/2007 1:43 AM
