254mm bars
508mm wheels
114mm pegs
343mm chainstay
533mm tt
Take a whole lot of getting used to, even for me.
It’s cycling in general. But it’s also a lot of other things, like fluids, wood, calibre of a firearm etc.
But with imperial you also have the decimal and the fraction, which is a bit of a ball ache to convert from one to another then into mm for us metric countries.
But it’s also in spelling, and definitions of words between proper English and American English.
But it’s been the way for a long time. Changing it would just be more confusing really
It's just different ways of saying the same things. I don't know about other countries but here, we grow up with and use both systems at the same time. In this case, the difference in units keeps large numbers short and sweet, and the small numbers precise, all without confusing anyone.
Fair enough...
I am capable of figuring out the dimensions of an object regardless of units of measurements but It just feels like a very fragmented system when you think of it as a whole.
I am willing to accept this but will continue to lose sleep over it. I haven't had a good nights sleep since I learned I was only 190.5 mm
Doesn't bother me at all. It's pretty normal here to deal with both systems in the same day. Look at the pipe fittings here for hydraulics and pneumatics: they're typically a standard or NPT imperial thread with a metric spanner head. The only measurement we don't use here, off the top of my head, is fahrenheit.
Also. If America has one reason to convert. Its cups. Wtf is a cup? Can't even convert it to grams. Cups only convert to milliliters. Who measures a solid in a jug?
Sort it out.
The Jap cars are at least consistently metric throughout. The domestic US cars got really bad with the mix of metric and English through the late 80's and into the 90's. I feel like I shouldn't need to know that 8mm is near enough the same as 5/16, 11mm as 7/16, 13 as 1/2, 14 as 9/16, 19 as 3/4, and etc. At least it transfers to bikes and other stuff here and there. And, yeah, you start talking mm's and kilos around here most people will just look at you weird.
As far as the cups and ounces thing, you have fluid ounces that are volume and other ounces that are weight, whereas grams are a measurement of mass. Mass here doesn't even have its own standard. It has to be a function of volume and weight ie: pounds per cubic inch. I guess you could even use fluid ounces per weight ounce. How many ounces in an ounce? Lol, lot of sense that makes.
Also, I forgot to say in reference to the OP, I wouldn't mind seeing more use of metric. It's a better system and the measurements seem a little more manageable, to me at least, if you use a decimal and/ or round the numbers when possible, like using jbales first reply with cm as an example:
25 cm bars
51 cm wheels
11.4 cm pegs
34.3 cm chainstay
53,3 cm top tube
Now that you mention it, pretty much is a standardization in that it uses both systems really well.
Never actually thought about it but it also teaches (those willing to learn) a better understanding of metric vs imperial.
I think it's a simplicity thing. When you look at what the list looks like it starts looking convoluted. Whereas the "mix" isn't as confusing. 21" tt is easier to remember than 533.4. Now, throw in the fractions.... "What size is you frame? It's a 539.75mm (21.25")." Even in cm, it's not as clear cut 21 = 53.34 & 21.25 = 53.97. Now when you say "I want to get some 165's or 170's", pretty much everyone knows what you are talking about without saying "cranks".
a cup holds your junk & keeps it from getting smashed.
On a related note, I don't know that the US created those measurements. The UK created "inches, feet, etc...." Now we're being told that WE are wrong for using it?
Lastly, in cooking, what do people in the UK use as forms of measurement? What do you recipe's call for (i.e. 2 cups flour, etc..)?
jbales wrote:254mm bars
508mm wheels
...moreMishinn_Control wrote:I think it's a simplicity ...more
Unless the measurements were rounded up or down. So instead of a 21” tt, you’d have 533, with 527mm replacing 20.75 and 539mm replacing 21.25.
Other brands already do this, only it’s outside of bmx. I know when I was looking at different street mtb frames a few years ago, literally every part of the frame was measured in mm.
Bmx also measures bb height in a retarded way. All other frames it’s measure from centre to centre of the dropouts, then in a straight line following the seat tube. So a street mtb would be +7mm, and a road bike would be -10mm. Rather than some vague measurement that entirely depends on what tyres you have.
Mountain bikers are another breed though! Surprised they don’t wanna know what angle the head tube badge is stuck on! Confuses me no end looking at an MTB geo chart! I just look for HT angle and CS length when I buy an mtb, not dissimilar to how I buy a BMX frame!
jbales wrote:Also. If America has one ...more
Mishinn_Control wrote:a cup holds your junk ...more
Grams of flour, litres or ml if it’s fluid! A cup is what we drink tea out of haha
10" bars
165mm cranks
20" wheels
30mm rise stem
4.5" pegs
14mm axle
13.5" chainstay
32mm offset fork
21" tt
Etc.
Etc.
Etc.
Bmx has a solid set of standardized parts that are compatible across a multitude of brands but they can't seem to agree on a way to measure things. I know brands come from all over the world but I really wish for the sake of simplicity, companies could just agree to make parts with metric measurements.
