If the internal axle is ti and the bolts are chromo I think it would be fine
Wish they would make a ti internal axle for the clutch lol
Testimony and apologies
instagram
old edit
OneGuyIlluminatiEye wrote:If the internal axle is ti ...more
Lol that’s why I got rid of mine tbh
just living with autism and riding bikes
I would suggest running case-hardened or chromo bolts with titanium axles regardless, because titanium on titanium seems to gall up quite a bit. Definitely put an anti seize Compound on it
Are you needing to replace the axle or just wanting the weight savings of titanium? If weight is the main concern, I would recommend plastic sleeved pegs with an aluminum core over a titanium axle. It would end up being about the same price of the axle to get 4 new pegs.
Reducing weight further away from the center of the bike will also make the bike feel lighter and more maneuverable.
I dented an aluminum peg recently but overall I have been extremely pleased with the durability of aluminum pegs with plastic sleeves as long as you rotate and change the sleeves out when the plastic gets thin enough to expose the core.
All this being said, the titanium axle will probably be fine and last a lifetime If you end up going that route or already run aluminum pegs.
I run the ti axle and driver on my z coaster and the only problem I've encountered is that the axle nut (steel) doesnt want to stay tight.
Maintenance guy at The Railyard Bike Park in Rogers, Arkansas
facebook.com/TheRailyardAR/
Insta @the_railyard
facebook.com/tedhuie
Insta @ted_danger
Alright so I want to get a ti axel and ti driver for my z coaster, but people say that they snap ti axels a lot grinding but my theory is that if I get a female ti axel and ride a cromo bolt, the bolt is more likely to snap then the axel. Is that theory correct? Because if you think about it, if you ride a female axel your bolt takes all the force from grinding. Thanks in advance to anyone that can help!! And merry Christmas and happy new year!
