georgebooky georgebooky
2/22/2018 5:34 AM
When I ride off ledges or steps and land even into transition so not that hard of a landing, my bars slip, I have to undo the stem then straighten them and tighten it again, this happens almost every time,
Do I buy a new stem ? New bars ? Or what ?
| Quote
Aitkenisgod Aitkenisgod
2/22/2018 5:45 AM
First I would take it apart and make sure the clamping area on the bars and stem are clean, then stick it all back together and tighten it up as much as you can without threading the bolts.
If it keeps happening then you need to get a new stem.
| Quote
Bulletpup Bulletpup
2/22/2018 6:22 AM
Aitkenisgod wrote:
First I would take it ...more
Ya, dont strip out the threads. Chances are the steel bolts will win against the aluminum body! Lol
But I agree.
What tool are you using to tighten the bolts?
| Quote
2/22/2018 6:39 AM
Bulletpup wrote:
Ya, dont strip out the ...more
Literally just an Allen key set ....
| Quote
HardBMX_Tim HardBMX_Tim
2/22/2018 7:17 AM
Clean the clamping surface of your bars and stem. Often times, small metal shavings will collect in there and cause the bars to slip non stop. Then tighten your bolts in an X-pattern.
If that doesn't help, it's time for a new stem or bars. Make sure your bars aren't crushed at the clamping area.
| Quote
Bulletpup Bulletpup
2/22/2018 9:24 PM
georgebooky wrote:
Literally just an Allen ...more
Like on a multitool or the individuals?
Sometimes it helps to get a bit extra torque from a tool with a handle. When I use the individual keys I tighten the stem bolts as much as I can until my hand hurts.
| Quote
grumpySteve grumpySteve
2/22/2018 10:47 PM
Could be your bars. If they're slightly crushed they'll slip easier. It's worth doing all if the above first though
| Quote
p1p1092 p1p1092
2/23/2018 3:41 AM
Make sure that the faceplate is sitting parallel to the body; if it's not, your bars will slip very easily
| Quote
McPikie McPikie
2/23/2018 4:33 AM
Might be worth giving your bars a light sanding on the area the stem grips?
| Quote
DanTheBikerMan DanTheBikerMan
2/23/2018 8:38 AM
McPikie wrote:
Might be worth giving your ...more
if you do this, make sure it’s a very light sanding! knurling will come off very easily if sanded vigorously.
make sure your bars aren’t crushed, and if they are, buy new bars.
Ride hard or Ride home.
Pink N’ Pretty
Instagram
@tarsales
| Quote
nocoast nocoast
2/23/2018 9:24 AM
tighten in X pattern
| Quote
STREETFIGHTER50 STREETFIGHTER50
2/23/2018 9:29 AM
| Quote
michael.eckhart michael.eckhart
2/24/2018 6:17 PM
georgebooky wrote:
When I ride off ledges or ...more
What stem and what bars do you have. Or post a picture with it taken apart.
| Quote
Post a Reply
See All Deals »
THE SHOP
