Timo.da.man
4/11/2019 1:38 AM
So I bought some new kink wright tires in 2.2 this is going from animal GLH tires in 2.25 but for some reason the kink tires are so much slower I thought narrower tires were meant to feel faster even though it only .05. But it shouldnt feel slower should it?
| Quote
Mishinn_Control
4/11/2019 4:31 AM
What PSI are you using? The lower the PSI, the more "sluggish" they'll feel. Also, tires are made differently. Some bay have a softer sidewall & if you are running the same pressure as your old tires, that had a stiffer sidewall, they will feel more sluggish as well.
| Quote
Whookid570
4/11/2019 4:50 AM
If I’m not mistaken they make 2 types. One for 65 psi and a HP for 100 psi.
| Quote
Mishinn_Control
4/11/2019 5:03 AM
Whookid570 wrote:
If I’m not mistaken they ...more
Either way, you could run 75-80 PSI in the 65 & + on the 100 if you wanted. Tires are tested to withstand pressures beyond their recommended PSI. I forget what the percentage is but it's like 20% or something like that. Someone who remembers might chime in on that.
| Quote
falloftroy20
4/11/2019 7:25 AM
Hahaha I had Kink Severs for a while and those were the slowest most sluggish tires I've ever had. Sounds like Kink tires are just no good
| Quote
adamnmexican
4/11/2019 7:35 AM
you want tires that are insanely fast as fuck? 1.75 odyssey frequency g tires
http://flatlandfuel.com/odysseyfrequencygwirebeadtire.aspx
fack off
| Quote
stahl4130
4/11/2019 8:17 AM
Rim width, TPI and pressure all play a hand in the way a tire feels and handles.
Make BMX Metal Again!
Pedal Driven Cycles www.pedaldrivencycles.com
Mainline Outdoors www.mainlineoutdoors.bigcartel.com
| Quote
XxCAKEWOLFxX
4/11/2019 9:58 AM
This is why I wish tires had a durometer rating in the description. Much better than “with a stiffer tread than last year”
| Quote
standardbmx14mm
4/11/2019 10:45 AM
My tires say max 65 psi. I run 55 psi rear and 45 psi front because I'm a fattie.
| Quote
readybmxer
4/11/2019 12:37 PM
If anything, pump them up. If not, your next pair should be thinner.
I run 90 PSI in my 1.96” Maxxis tires. Speed for days.
Scooter kid trying to ride a bike. Instagram: @scootereyn // YouTube: RH MEDIA
| Quote
stahl4130
4/11/2019 1:17 PM
A higher TPI rating will give you a stiffer casing to the tire. Wider rims support the side wall of the tire as well, allowing for less deformation under stress.
| Quote
Swaggy P
4/11/2019 1:19 PM
I ran the GLH 2.25 looking for a puncture-resistant tire and found them to be sluggish feeling, so I could only imagine what those Kink tires must feel like.
Ive tried 5 different tires (Demolition Momentum, Odyssey Path Pro, Cult Vans, Animal GLH, S&M speedball) and the S&M were the quickest, most agile feeling by far. The Demolition Momentum were close though.
On the advice of posters here, I'm gonna try the Fit FAF and the Eclat Mirage but if I don't like those tires, I'm just gonna stock up on the Speedballs and call it a day. I'm hoping to find a tire that's fast feeling and somewhat puncture-resistant (the one downfall of the Speedballs) and both the FAF and Mirage have some sort of extra layer to resist punctures.
| Quote
Timo.da.man
4/11/2019 4:07 PM
Mishinn_Control wrote:
What PSI are you using? ...more
I run 80-100 psi so that shouldnt be the issue
| Quote
XxCAKEWOLFxX
4/11/2019 4:17 PM
Are you comparing new to new? A worn* out tread will always be faster because theres less tread adding to your rolling resistance. If you are, and ur running high psi, then its def just the softness of the rubber.
| Quote
Timo.da.man
4/11/2019 6:58 PM
XxCAKEWOLFxX wrote:
Are you comparing new to ...more
That's probably the reason I ran the animal tires to the very last legs of there life thats explains it
| Quote
threesomemist
4/11/2019 7:47 PM
A lot of new style tires feel sluggish because they a being made with the assumption that most people run 25 psi and want balloons for tires.
| Quote
Post a Reply
See All Deals »
THE SHOP
