They're hard anodized. They can be blasted and powder coated without taking them down to raw
HtownGetDown wrote:They're hard anodized. ...more
If you're talking about sand blasting, then Yes, it will be raw/bare alloy. I wouldn't ever sand blast a rim you'd chew through it.
You can actually un/de-anodize them and then re-anodize them any colour you'd like, but its finding a place to do it.
And if they are powder coated just use paint stipper to remove the paint and choose how you'd like to coat them, anno, powder coat etc etc.
Cellmember wrote:If you're talking about ...more
Wut.
HtownGetDown wrote:Wut.
You mentioned the rims can be blasted and I responded if you meant sand blasting, which is a process which removes debris/paint from certain materials.
Cellmember wrote:You mentioned the rims can ...more
I understood what you said, I was just confused as to why. You can blast 6000 series aluminum without chewing through it or getting it back to raw. It just needs barely roughed for the powdercoat to adhere, which can be done over anodizing easily
If you're going to use brakes on the rims I'd recommend re-anodizing them as it's the strongest for wear instead of PCing, but if not then PCing would do just fine.
HtownGetDown wrote:I understood what you ...more
It's to easy to pit the alloy I wouldn't do it either way. You'd get a much cleaner/safer job using paint stripper if it's power coated, and de-anodize if anodized, you'd be crazy to blast an ano rim right.
Cellmember wrote:It's to easy to pit the ...more
Lol, ok.
If only someone would invent different kinds of blasting mediums or something better suited for softer metals....
HtownGetDown wrote:Lol, ok.
If only someone ...more
I did say sand. But what medium would you use to remove anodizing without damaging the alloy ? Curious.
Joke right?
There's many kinds of blasting media, for blasting anything...
Oven cleaner and some muscle will take the anodizing off but in my experience the G-Sports use an anodizing that's harder to remove. I had to really work for it to remove the anodizing on my old ones.
Sandblasting at a lower pressure if possible would be more ideal if you can.
If only someone ...moreBlack Swamp Ghost wrote:Joke right?
There's many ...more
Yes it's a joke. I use blast cabinet almost daily
HtownGetDown wrote:Yes it's a joke. I use ...more
What medium would you use to avoid damaging the surface ?
Cellmember wrote:What medium would you use ...more
#100 aluminum oxide works fine and is more than likely what a PC shop has loaded up in their cabinets anyways
HtownGetDown wrote:#100 aluminum oxide works ...more
Nice, I'll check it out and do some research on that, as I'm going to be in the same boat as OP soon and need to redo some anodized rims. Structurally they are fine just the ano that's beat up, strip and re ano as I use brakes.
Cellmember wrote:Nice, I'll check it out ...more
If you aren't PCing them and plan on anodizing them again, just grab a bottle of Greased Lightning from your hardware store
I've used the oven cleaner method, worked pretty alright.
readybmxer wrote:I've used the oven cleaner ...more
Second this.
Does anyone know if you can even powder coat alum.? When I rattle can over alum, it never really seems to stick as well as to chromo, maybe that's coincidence. But I know rattle can and powder coat are two totally different things anyway...
Instead of fighting with oven cleaner or having them blasted - just buy some of the powdercoated limited edition colors & soak them with aircraft stripper.
We also have a set of raw Aerospace rims here at powers if you’d like some that are ready for powder!
Real powder coat laughs at most paint strippers and most chemicals.. It's not a paint like enamel or laquer, more like a plastic coating/powder, baked, and melted on.
The only way to take off real powder coat is blasting, sanding, acid dipping..
Nothing really likes to stick to aluminum generally speaking.. Even powder coated aluminum chips easier and bigger chipps than steel or molly coated the same.
Anodized aluminum can be easy or tough to remove the anodized coating with oven cleaner, depending on the molecular depth of the coating. I've tried some parts that only got lighter in color and not straight raw with that process. Anodizing is tough, for real...
Just my experiences, restoring you name it...
Correction/edit, the only coating that really likes to stick/take hardcore to aluminum alloys is adodizing...
Black Swamp Ghost wrote:Correction/edit, the only ...more
Powder coat takes to properly prepped aluminum and aluminum alloy with no problem. A lot of manufacturers powder coat them despite anodizing being cheaper. One of my best dudes runs brakes on a rim he powder coated a couple years back and it still looks mint.
I've never had to sand blast anything but always wanted a cabinet. Isn't there less abrasive material you can use with a sand blaster for different metals? We had to send out a cylinder head once on a Mini cooper to have sandblasted with walnut shells/ Dust.
Black Swamp Ghost wrote:Real powder coat laughs at ...more
I had a powdercoated frame and I used paint stripper on it, took it off in 3 coats. Came off kinda like how plasti-dip does-more peeling than anything, but it did bubble etc.
BUT it was a lot more work than typical paint.
I would be cautious on oven cleaner on alloy to remove ano though-heard of it pitting if you leave it too long (not sure how valid that is)-I would probably just soak a rag and scrub to avoid.
I strip powdercoated stuff multiple times a week with cheap Walmart stripper. Bars, frames, alloy bits - you name it.
It’s much less time consuming than using oven cleaner on anodized stuff - and without the risk of pitting the metal if you let it soak too long.
That’s just my experience with stripping BMX parts for work anyways.
Also, it’s worth mentioning that I use the aerosol stripper. The stuff that comes in a tin can, like paint thinner, acetone, etc. doesn’t usually stand a chance against powdercoat.
Question about the black Odyssey and g-sport rims. Are they just powdered black? Can you raw them and re powder coat them a different color? Kinda sounds like a dumb question but I want to buy a couple to re powder coat a different color.
brakeless maniac
