finwalker.12 finwalker.12
2/26/2020 10:03 AM
My cranks are sticky when i pedal they are fine when i pedal them to the bottom but when the crank arm faces up it gets stiff and makes a rubbing noise its still rideable but its rlly annoying
| Quote
BmxInTheUsa BmxInTheUsa
2/26/2020 11:37 AM
I have had that when my chain was to tight or my bolts were loose
| Quote
p1p1092 p1p1092
2/26/2020 11:40 AM
Does it happen with the chain removed from the sprocket?
| Quote
2/27/2020 1:59 PM
p1p1092 wrote:
Does it happen with the ...more
No I haven’t tired yet thx I will
| Quote
2/27/2020 2:01 PM
BmxInTheUsa wrote:
I have had that when my ...more
Idk if it’s the same I can feel and hear a rubbing sound went I pedal it gets stiff and then unstiff but I think it’s definitely from my cracks bb or sprocket
| Quote
2/27/2020 6:00 PM
maybe your bottom bracket or spindle and cranks need cleaned and regreased.
| Quote
2/27/2020 6:01 PM
if that doesnt help tell me for it might be your bb bearings and i know how to help with that
| Quote
p1p1092 p1p1092
2/27/2020 6:38 PM
BmxInTheUsa wrote:
maybe your bottom bracket ...more
First step is to eliminate as many possible causes as possible. There's no sense in just blindly trying to fix it; that way they'll end up fixing it until it's actually broken. They should start by removing the chain, to try and isolate the issue to the bottom bracket/cranks/sprocket area or the rear hub. smile
| Quote
2/27/2020 6:58 PM
good tip p1p1092
| Quote
2/27/2020 6:59 PM
Then you should be able to isolated the place of the problem without needlessly taking things apart.
| Quote
Post a Reply
See All Deals »
THE SHOP
